Help please?
I used boolean to model this interior and maybe thats the problem.
I used pretty hi settings and image took 3 hours to render on dual proc, quad cores pc.
And I got splotches.
spots
Did you try doing a material override? I bet your stained glass is causing them.
It only happens on objects with boolean modifier.
The material for windows colored glass is simple vray material with map in refraction slot, but it’s the same even without them.
The dots are following mesh polygons exactly and thats why some of them are square shape.
I have uploaded the scene on rapidshare, here is the link:
http://rapidshare.com/files/237740067/church\_interior.rar.html
This look like the same spots I had in one of my scene, a plane interior, here s my post:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?t=45472
I have sent the files to Vlado over 2 weeks ago, did’ nt get any feedback yet.
Im still wondering what cause thoses spots, I had it in my pre-cal Irr.map.
Are you using SP3a ?
These are the results I get with the scene you posted:
Here is the file but it is saved in 3ds Max 2010:
file
Edit: Rendered it with your default settings and got no artifacts. Third render:
looks like caustics splotch
Could you upload scene with your settings for max 2008.
