deneb26
September 7, 2007, 6:25am
1
hi guys
i’m trying to do an indoor night-scene with a tv on.
the tv-light is made of a vraylight-material.
should i use a seperate vraylight to avoid the splotches or do i have
to change some settings in the irrmap/LC?
comments are appreciated, thanks.
regards ale
tammo
September 7, 2007, 6:35am
2
“should i use a seperate vraylight to avoid the splotches?”
yes that will get rid of the splotches or change to QMC for first pass.
DaForce
September 7, 2007, 7:27am
3
For a shot light that putting a vraylight infront is a better option.
And as tammo said it will get rid of the splotches without the need for high render times. Or switching to QMC which would generally end in high render times.
alexthg
September 7, 2007, 8:20am
4
Another alternative is using vraylight plane in front of the TV, with skylight portal ON.
deneb26
September 7, 2007, 9:29am
5
thanks guys
i’ll consider your tips and will render the whole scene again.
ale
Neilg
September 7, 2007, 9:49am
6
This is how i’d do it, the colours it gives off will match whats on the tv then.
hi ale
in irrmap take the high preset and set the min/max to -6/-1.
I promise the splotches will disappear.
best regards
themaxxer
_Lele
September 7, 2007, 12:31pm
8
http://www.chaosgroup.com/forum/phpBB2/viewtopic.php?p=174452#174452
Maxxer well knows
Follow the links in the thread above to see more examples of how that works.
exactely lele. thanks a lot!
best regards
tehamaxxer
deneb26
September 7, 2007, 12:59pm
10
ok my puters are rendering…will take a while since i’m rendering @3500 .
for the moment i want to share a wip i’m working on.
alexthg
September 7, 2007, 1:17pm
11
very cool rendering! nice texture & lighting mood
water a bit too calm for me, looks kinda like glass. Maybe add a bit glossiness, or add more ripples?
this one went under the radar a bit…good render of a nice space…are they wires running overhead?
the glass like calm of the water is what makes it…but maybe you’d very rarely get water that calm in reality…
