spot light help
I have interior render , I used Fernando’s method
I put some spots and some light with rectangle light but when the render is finished i dont see any light for spot light with ies and light with rectangle light
can i anyone help me
i increased intensite for this light but i have the same problem
thanks
tuto for Fernando’s method
http://www.youtube.com/watch?v=KuEa0Mhi5I8
Re: spot light help
Hey robert.
I set mine to ~100,000.
Try cranking it up REAAALLY high. Depending on how much light is getting into the space you sometimes have to crank it up to ~1000000
-Gallystops-
Re: spot light help
basically, you’re competing against sunlight with the tutorial settings. You could either try turning the GI and TexSky way down, or like gallystops says, increase your lighting by a factor of 100 or so.
