Hello friends, I hope you are very well.
Here I come with a great doubt, which I have read but I am still confused.
In cinema 4D the color profile that comes by default is sRGB
As I understand for better results you should work to LINEAL profile
This works well with Vray, I wanted to know if it’s the same with Corona?
My question is: should I leave the color profile that brings 4D cinema or change it to Lineal?
Here I show you 2 scenes with the different color profiles using Corona.
the post parameters are the same, only the color profile was changed
Thank you very much for your help
regards
