It appears the SSS Surface ID available in Maya is not available in Houdini. Chaos Docs
Could you please add this or is some other workflow supposed to be used in Houdini?
-- Erik
-- Erik
Tnx, I’ll add the control to the object properties.
For now you could try manually adding user attribute “VRay_SSS_SurfaceID=<number>” into the object properties.
Manually adding it to User Properties dont appear to work so would be great if this could be added as soon as possible. Need it for a project.
-- Erik
Well, adding this control will internally do exactly the same - will add this specific user attribute. It seems to be exported correctly to me; may I check your scene?
It ended up being an artist not taking into consideration the difference in default units between Maya and Houdini. Will still be nice to have it added instead of using User Attributes but not urgent in any way anymore.
-- Erik
