Sss trace sets possible with sss volume shader?
I know that you have sss id sets in vray - As I understand it this works for fastsss and maybe others, I want to do this with sss volume shader too - This does not work as of now (as far as I cam see)
  • Is this something that would be possible?
Image from Karma render manual for example:
I don’t think it works for anything other than VRayFastSSS2.
Moving the thread to Requests. @dimitar_panayotov will assess the matter and evaluate its implementation.
Which shader are you referring to when saying “sss volume shader”, btw?
The «standard» vraymat sss on «volume» - I tried this with a vrayvolume shader Also seems to work with The shader alone - but same results when put in a blend material.
Ideally some sort of render time Boolean “union» would solve this? i did some testa earlier with renderclip, didnt work great with The volume sss
I can’t make it work with anything other than VRayFastSSS2.
I’m still not sure what your setup is; from what I understand regular VRayMtl with translucency set to SSS ( which you claim works?) / Volumetric (which you want to support SSS IDs)?
Yes, Sorry if I was unclear, But when using standard vray mat with volumetric sss - The result when you have intersecting geometry Is as in the first example in the image included in the first post. What I would like is some way to aviod artifacts when two objects with the same sss volume material intersect. As in the second example in the image. As I understand, and as you say this only works with vrayfasttsss2.
How you make it work, is not relevant, I would only like to have an option to make this work as in the example provided.
Understood. We’ll discuss it with the devs.
