What model are you guys using these days for Stable Diffusion?
Get a Gemini api key or one from stability if you want their model. Gemini is more robust than stability from my experience.
Please elaborate> How do I download Gemini and get it into Stable diffusions?
No — “nano banana” isn’t a feature you run inside Stable Diffusion. They’re separate, competing tools.
Nano Banana is Google’s image generation/editing model (the nickname for Gemini’s image model, Gemini 2.5 Flash Image). It runs through Google’s ecosystem — the Gemini app, Google AI Studio, and the Gemini API — not inside Stable Diffusion’s pipeline.
Stable Diffusion is a separate open-source model run through interfaces like Automatic1111, ComfyUI, or Forge. You can’t load Nano Banana as a checkpoint or model there because it’s a closed, API-only Google model.
If you want similar conversational/prompt-based image editing in a local Stable Diffusion setup, the closest equivalents are tools like FLUX Kontext, InstructPix2Pix, or inpainting workflows in ComfyUI.
-from Claude.
I love the bottom image. The first one is nice too, but the bottom one is awesome!
Stable Diffusion running it locally requires a fairly powerful PC, especially with the newer models.
I tested it on my PC a while ago. It’s great that it’s free, but it also requires quite a bit of setup, tweaking, and experimentation to achieve results comparable to some of the other paid AI image generators available today.
