The amount of stairs is the same as in the image (less even). What I did is take the average height of a floor (3m) and divide that through the maximum height of a step (18,5cm) which results in 16 steps. I used one more…
With hinges you mean on the door? In the original image, the hinges aren’t visible, but I modelled that door for another project and decided to use it again. I used a door in our office as a reference (it was 2.7m high).
The exterior seems very strong compared to the interior. Cant tell without seeing the photo how close it is to reference but usually if you take a photo inside looking out the exterior is very blown out if not completely white.
like thablanch said some more contrast would help and the stairs mat looks a bit flat could do
with some more something, not sure what.
really like the shadows falling through the stairs onto the wall, might be nice to do a cam from an angle close to that wall looking up through the stairs or down near the water.
By hinges, I mean the spacing between them, the 2 one from the top are closer together than the other ones. Could be the design.. it is a question.. but more design related than image related..
@pg1:
That’s a nice suggestion. I’ll see if I can make another shot from this scene.
@drisk:
The contrast remark has been made a few times now, so I’ll go and look into it. And thanks for the volume light suggestion.
@thablanch:
I haven’t exactly used standard distances, but it happens with high doors, that there are two hinges at the top of the door to stabilize it (I’ve worked for a contractor as a part-time job during high-school). It could be that the spacing should be a bit different though.
