First of, i have no idea if this is even possible, but what about a Standalone Solution for Corona Network Rendering?
We have a small renderfarm consisting of one Server Machine and two client Machines. The server runs cinema’s teamrender server, the clients run cinema’s teamrender client software. To be honest, i’m sick and tired of cinema’s teamrender solution in this configuration. The server software is just not robust at all. It is very delicate on how fast you start jobs after each other, cancelling and deleting jobs is just a plain nightmare. When you have to restart the server software, all of a sudden, jobs with status finished are in the queue again, even jobs you manually deleted on the servers file system are back after a restart and blocking the queue with status “failed” wich forces you to restart the server again. It’s simply not possible to rely on that setup at all.
So my hope is, that you can come up with something robust and relyable, so that i can just drop as many jobs as i want and it renders, without having me to check every 30 minutes if everything runs fine.
What you are looking for is a Rendermanager like: https://www.royalrender.de/index.php/startseite.html
I was so sick of the whole Teamrender shit, as well. RoyalRender woks really well and there is a nice and fast support.
Deadline is another solution, but I don’t know anything about this product.
RoyalRender is only a render manager. It has very little to do with the RenderEngine.
You need the C4D Commandline-Render license, that is available in Packs of 5 lics and the Corona Render Node license.
We use C4d with Corona as our main RenderEngine, all managed by RoyalRender.
As long as you have the C4D commandline licences and sufficient Corona render node licences then should be good.
Central storage such as NAS and a machine to run the Deadline database are best. Once the initial head scratching of the install is done it’s solid. It’s free for 10 users nowadays.
