http://www.oxyshare.com/get/61614651744f43c4707016/Anything\_To\_Phys\_Cam.zip.html
http://www.oxyshare.com/get/90300964644f44fffa017a/PPT\_Calc\_B.zip.html
Fixed for both the installer, embedded in the script.
Extract, run the .ms from within max (disregard the .mse files),done.
They’re now both under MaiUI->VRay, ready to be bound.
For those which tried the hand installation of the previous standard_2_physcam, please remove “MaxCam_To_PhysCam_proc.mse” from your “UI/MacroScripts” folder before installing the new one.
EDIT: no need anymore, new script version takes care of it.
New version renames correctly also the camera target (duh!)
EDIT: and it contains the perspective to physcam tool: with no selection, it turns any viewport to a physical camera, with a standard camera selected it converts it.
The other ppt calc had some major math issue (I’m open to math lessons: multiplication, divisions, reciprocal functions and so on. Elementary school at best: anyone willing to help?), which is sorted now.
EDIT#2: fixed small update bug in the ppt calc and optimised the installer part to match the camera script’s one. Note that to update changes in Rendered image size in the Calc, you need to CLOSE the render dialog. Having to close the render dialog before the width and height of the rendered image are updated is a Max behaviour i couldn’t get around.
As per usual, avoid downloading and using them, unless you feel an itchy urge to do so ![]()
EDIT: sorry for the continuous update on small stuff, but i’m stumbling along with ideas. Let me know if the hijacking is too much ![]()
Lele
