Hi there,
i just dowloaded your great 1.00 Version and i like the Button for Interactive Rendering under “General Setup”. When i want to stop the interactive to save CPU Performance and press Start again the Rendering starts.
In my opinion a “Restart Interactive” Button would be a nice thing here
I’m not sure i understood your request the way you wanted, but there is a way to start interactive rendering directly from VFB. Just press and hold regular Render button and another button will pop out, which will let you start interactive rendering.
Also, you can limit for how many passes interactive render will calculate after each change: Render Setup>Performance>Performance Settings>Interactive Rendering> Max Passes
It´s nearly the same I just would like to habe the Button on the Vitrual Frame Buffer Window I can´t start IR with the “normal” Render- Buttons. Can you assign Corona as Active Shade in the Assign Renderer Tab? When i start Iteractive or Active Shade the Pop- Up Windows are static. I need to get to Scene → General Settings → Start Interactive or “enable” IR in one of the Viewports. Is this any different than your configuration?
1 for “pause” IR. I know this thread has been closed for now, but this feature is really needed. Not just for floating IR but also for viewport IR. I’m mostly (almost only) using IR in a viewport, and the only way to stop or pause it rendering to free up system resources, is to switch view (leaving IR mode). And then the opposite way to activate it. Not at all a quick way.
I think a nice and easy way to do it in both modes, is like most media players do it: click in the viewport, and it’ll stop or start, depending on the current status. When in “pause” the well known pause sign could be shown in the render view.
Hope these ideas will find it’s way into a great renderer
