Startup time
compared to the old PDPlayer the Chaos Player takes considerably longer to open. So if I try to open any picture files it takes a few seconds before Chaos Player opens up while with PDPlayer it instantly opens. I would like to use Chaos Player as my general picture viewer but as it is now it gets a bit annoying always having to wait a few seconds until the software starts up.
Any way this can be improved? :slight_smile:
Hi, we’ve had this report occasionally, but we’ve had little luck reproducing it on our end and debugging it.
If you’re up for it - can you try this build? https://drive.google.com/file/d/1e8VwtnI7vSQp\_D0aunsSrRVniDOMDv-x/view?usp=share\_link
If possible - create a windows dump file *WHILE* the slowdown at startup is happening and send the dump file over.
This will hopefully contain some clues to where the problem lies.
You just nee to select right click > create dump in the task manager.
Hi, I installed that version but it’s still the same. It takes roughly like 4 seconds to open any picture with Chaos Player and for the dumpfile it doesn’t show up in the Apps during the startup so it’s not possible to create a Dumpfile WHILE the slowdown happens.
Hi, just click on it when it first appears, you can press the “C” button when you are in the taks manager, it will show you the process with name starting with ‘c’. Also does the player open images slowly when you open an image throug the menu (when the player is alredy openend)? Also if you open the player without image does it sstart slow?
Hi, I answered the question in the post before. Somehow the forum has some hickups recently. Also click on the “DumpFile” in the post to download the dumpfile…
Any updates on this? I am short of uninstalling it, so just wanted to know if there is any fix for this as for now its too annoying to use unfortunately…
Hi, the problem is that the new features that we added to the player and the chaos licensing integration are adding to the startup time. I’m working on it currently, but it may take time. I will do anything to fix it in the new update that we are preparing for this month.
I’m sorry for the inconvenience and thanks for the feedback.
Hi, thanks for the info! Then I will keep my fingers crossed and wait for the update!
Hi, I think that most of the startup time issues have been eliminated. Could you try this new version and tell if there is improvement on your side?
Regards,
Asen
I just tested it quickly and it is much better now and seems to open pretty fast 8)
Not quite as fast though as the standard Windows Photo Viewer, but that’s probably an unfair comparison as the featureset is different. So Chaos Player takes maybe 1-2 seconds to open and the standard Photo Viewer like 0,5 seconds.
Anyway, huge improvement to before, thx a lot!
I just wanted to update this thread and say that this change is going out with the next release (Update 1.1). It’s already available in our stable builds: https://nightlies.chaos.com/#/chaos_player/stable
