Stereo Camera DR render not supported?
Am I correct in assuming from the crazy bucket errors I’m getting, that Stereo Camera rendering is not supported by DR?
It’s working fine here. What are your V-Ray/Maya versions and can you share the scene and a screenshot of the issue to support@chaosgroup.com?
Could you please let us know what Maya and V-Ray versions you’re using? Also, could you check if the DR machines use the same version of V-Ray, this may happen if there’s a version mismatch.
It would also be of great help in figuring out what the problem is if you could send a scene for investigation to our support team, like Miroslav suggested.
Thanks.
