3d max / Corona render 1.4 / Ps
Model from http://3dsky.org /Thank.
Did you use some sss for the marble?
Try to add some translucency to see the result, you can see how it’s used here:
Thank. JacopoGrosso
You should break up the mantle into 4 separate pieces with their own mapping(top, side columns then the main scroll work). A fireplace hearth like this wouldn’t be made from one solid block of marble, so the veining shouldn’t bleed from one section to the next. Just a detail that would add some more veracity to the image. Otherwise looks great.
Thank.mferster
What is the light condition here? I like it.
