Still noise
Guys Need One more help
Still noise after 23 /38 pass
how can i reduce this noise?
Number of passes does not mean anything. How much time did it take to render?
You are using strange sampling settings. Doesn’t it render faster if you reset to defaults? (GivsAA and LSM)
How are the ceiling lamps made? Can you show viewport screenshots?
no it takes time but before that sampling there was to much noise , after doing that it reduce but not going permanently
last 38 pas take more then 30 min
You are rendering with 64 gi samples and 256 direct light samples per pixel per pass. That is a lot. No wonder it renders slowly. But it looks like something is wrong with the scene. Any chance you could upload it here or in our support system? https://coronarenderer.freshdesk.com/support/tickets/new
the zip size is to big to upload ,
is there any way?
like is there any problem on light ?
check those it might help you to find the problem
Nope, this does not help.
There might be some problem with lights, I do not know as I do not have the scene. How are they modeled? Can you show screenshots?
Sorry for late reply here is my screen share
We will not be able to help you if you cannot provide us with any useful information.
Can you show us a closeup of the light’s “frame” - the place where light is nested inside the case object, the glass, etc. I mean the very close view - so that you can see how it’s made. For example: if there is glass in front of the light. You should also select the light object and show the modify panel with the light’s properties visible.
No there is no glass in front of the light source
check the attachment of light option
Ok, what is this small white disc?
its corona light material…
even though delete this object i put for a render ,
still the same thing on
still there is lots of noise on CESSENTIAL_Direct
What is the size of the scene? Can you send it via WeTransfer to support@corona-renderer.com ? And/or start a ticket here? https://coronarenderer.freshdesk.com/support/tickets/new
sure
sending
File send_(Corona Test)
btw in your other Thread u wrote that you are using corona V1.1x
maybe updating to 1.3 wil help you also.
Greetz
Lucutus
Oh. So which version of Corona are you using?
corona V1.1x
Why?
