Stone wall Texture search
Anyone come across a decent texture based on this image : a natural grey alps schist ?
Arroway stone has one or two that might work if recoloured. Otherwise I’d suggest cropping that image and adjusting perspective so you can image search it maybe.
I had a look in google images for a slate wall texture and theres a couple floating around id suggest looking for that and seeing what you can find
www.lughertexture.com there are a few in the brick section that look pretty good as a match
i always forget about arrowway, cheers for the other link too.. yeah the google search didnt quite hit the spot…but will try the image search thing…thanks for help, much appreciated.
Megascans have a couple listed as castle walls that work for this type of stone. You can just subscribe for a month, download the textures you want and then unsubscribe. (You’ll lose access to the bridge app if you do so be sure you’ve already exported the material into 3ds Max firs)
