Is there a way to prevent the EXR output? I tend not to use it and it is a sizable file to download. I’m using vray fro SKP.
Thanks!
Thanks!
Hi @jacksivyer ,
Yes, you can select different output file type for your images. This is done in the Settings tab of the V-Ray Asset Editor. You have to expand the Save Image options and select the needed output file type as seen on the screenshot. Chaos Cloud will respect you choice when you submit the scene for rendering. Please let me know if this doesn’t work for you.
@vladie Yes, that worked for me, many thanks.
It was not so obvious to me!
