my scene has a strange bug everytime i hit sop render the render stop for 3 seconds and then start rendering again i have tested other scenes and looks like this is the only scene with this kind of bug
i need to hit stop render many times to stop it
by any chance… do you have multipass effect, rendering animation range, or batch render active?
yes, multipass is active the point is that in certain point i was rendering ok before this bug starts i think i pressed cancel and stop button at the same time and then this started happening anychance to disable multipass to fix it?
AFAIK this is 3dsmax issue (legacy crap), not corona - you should disable it in the camera
