I don’t know if this affect other users, but most of times when the Scene Parsing and Geometry is running and you press Stop - it doesn’t STOP.
Is the most annoying thing in Corona, that when you press the Cancel button or Stop button, it doesn’t stop the render. It has to go until the end of the calculation to stop. So, must of the times we have to wait like 15 minutes or 20 minutes until we can start work. Is this a bug?
its not the most annoying imo
yes sometimes i need it when for example when I forgot to run the render without turn off the displacement, canceling the calculation is the right time to do something we forgot. and, uhm it looks like that scene parsing / geometry calculation isn’t designed to be interruptible.
Does anybody know is this behavior occurred in other renderer too?
and, if it is possible I’d like to have interruptible sceneParsing/geometryCalculation in corona.
Computing sec. GI can be easily canceled so Parsing scene and preparing geometry should be too when corona team look on it .
I am not sure about the first pass Transforming Verticles, probably it is handled completely by max, you can not even move VFB window during it. For example in this pass is Forest pack calculating all areas defined by splines. In my last project I was forced to do some optimization in number of spline verticles(I save lot of time during this pass!!).
I dont know how big are your scenes, can you also do some optimization so the waiting for canceling would be not so painful?
I had a similar problem on my previous system which was a lot slower and at about 16 gig ram
especially with large scenes
With my new workstation with 32 gig ram and overclocked i7 at 4.8 I have almost instantaneous cancellation of rendering
I always just thought it was a ram thing, or just a general slow system thing and not the render engine per se.
The only reason I can think of would be running out of RAM. System becoming non-responsive in general is a typical symptom.
I had this situation where Corona would not react to stop/cancel buttons only once, and never managed to reproduce it again.
Yeah, I think a minidump could let the devs see what is going on under the hood.
Also, are you using some 3rd party plugins like Forest Pack here? Just a random idea, but maybe worth a try - could you disable “multithreaded parsing” in devel/debug rollout and see if it changes anything?
It happens to me and to my co workers quite frequently. What is annoying is that Corona just keeps the calculation like you didn’t press the Cancel or Stop button. Only, after finishing the initial calculations it stops, but the system stills responds. This happens when the scene is complex, but even when isn’t I had the same issue.
