It is always confusing to me if we have to press “stop” or “cancel” when we need to stop the render and resume it from the cxr file later.
In the updated “Corona Knowledge Base” web page it clearly states that you have to press “Stop”. However, on the included video on that page, which is old, the user presses “Cancel”.
Ofcourse, the difference between “Stop” and “Cancel” is the denoising part. If you press “Cancel” and then you resume from the cxr file, you get a warning about missing elements. I don’t know if you get that warning in the case you pressed “Stop”.
I know that there are a lot of old posts regarding this, however, I feel that none of them clearly states what you have to press in order to not get that warning, render your image and denoise it at the end without issues.
So, what is the official answer to this? “Stop” or “Cancel”?
TBH doesn’t matter really, dependent if you want denoising to happen there when you know you are going to run more passes on it later (might just want to save the time so go with Cancel). I don’t recall there being any visible difference in tests I did some time ago on this when resuming.
So what if I want/need to render my image in 3 equal time segments? For example, 6 hours per night. Only the passes of the last segment will actually affect the denoise result?
I understand your issue and confusion. The error should only appear when you use the “Cancel” button instead of the “Stop” button, because when you use the “Stop” button, denoising is calculated and stored with some hidden internal render elements in the CXR file. However, there is no denoising part happening when you use the “Cancel” button, hence the error.
Upon further investigation, we found that the error is still showing even if you are using the “Stop” button. We have logged this as a bug report in our system and will be further reviewed by our devs.
In the future, if you want to resume rendering for your files, consider using the “Stop” button, as this will save the necessary information for denoising to be used later.
If you used Cancel, then yes only the calculations in the last night of the 3 would be used for denoising. Most likely this would be enough though, and you wouldn’t notice any difference compared to saving the denoising calculations with a “Stop” on the first two nights, thus building up denoising info from all 3 nights. If you’re going to render 500 passes at once, then 2 passes later, best save that denoising with a stop, of course But if your “last run” is going to have a significant enough number of passes, the denoising data will do its thing just fine.
So choose which you prefer. “Stop” is the guaranteed safest, but “Cancel” in the earlier start-and-end render sessions will give the same results to the eye in most cases, so nothing to stress about whichever route you choose.
