Stopping color bleeding?
I was wondering if there was a way to stop color bleeding, or a way to control it. Is there a way to possibly have a light preserve the energy of its bounces, but not the color of the objects(s) it’s bouncing off of?
hi there
the only possible way that i know of , is to put the colour that you want to bounce …calculate the irr map and then save it , …load that file and then change the material to the one you want to be seen and then render it…
i hope i am making sense :slight_smile:
under Vray system…choose object setting…make sure you object is selected or hilighted and turn down generate gi from 1 to anything less.
Yes, but that’s turning down the energy of the bounce.
*Edit* Kippu, that does work, but I was wondering if there was a quicker way perhaps. Because I don’t want to be changing the IR map every time I make a change.
no, i dont think so…
render the whole file in in white (vray-mat) . then save the irr-map
and use this one in the original scene with color.
Are you sure this works. I tried it and had no luck.
