It doesn’t seem to be the individual scene. I’ve tried it with multiple scenes… opening and closing rhino to create ‘clean’ scenes. …same thing.
Just to rephrase the problem:
If i cancel a render then i can’t get Rhino to respond, but if i let the render finish. No problem. I don’t have to re-boot, just end the Rhino process with task manager will do.
So, …if you still want a scene that’s fine , …let me know. chris.
Yes…ESC does not abort the rendering if you have closed the dialog.
If you all want to cancel a render pressing ESC while the VFB is open will abort the render. Do not try and cancel the rendering with the close dialog button. In this case V-Ray continues to render. This is supposed to be this way. In the end I believe what we are shooting for is giving the user the ability to render and save an image without using resources to show the VFB.
