Storing Vray light with irmap
I am on a crazy deadline - doing HD stuff 1920 x 1080 for a dvd menu. Big title just opened ( can’t say exactly which one ) anyway I am doing a cityscape and have lots of shiny stuff and GI. I am using a single Vray light to provide illumination, pre-calculating the irmap,( lightcache for secondary bounce) calculating every 5 frame and them shooting it off to the farm.
My question is - should I check the - store with irmap option in the vray light ? - what exactly does this do ?
Thanks as always.
It bakes the shadows from your area light into the ir map so it will speed things up a lot. That said you’ll need to turn up the subdivs of the light to get it to store a decent quality shadow.
Rendertime
So at rendertime, can I turn off the shadows ? Should I leave the save with irmap checked ? I have done some small test renders using the irmap I created and I have a strange grain in the animation. The grain does not flicker it appears to move with the camera. Does this look or sound like a familiar problem to anyone
http://h1.ripway.com/Adam\_Stewart/Folder%20Name/GI\_s100\_134\_1.mov
Thanks as always for your paitent help.
Re: Rendertime
Yes you could turn off shadows, but the quality of the shadow will depend on the quality of your GI settings. If you can afford the render time I prefer to keep the lights and shadows.
The grain that doesn’t move is normal…I believe the solution is the little checkbox called “Time Independant” on the QMC sampler rollout.
Tim J
Thanks a million
Thanks a million. I have used GI in one or two projects, never anything this huge, It is going to be an interesting couple of days - working the weekend - wish me luck.
Thanks again.
Are the intials of the movie GR?
If you save your lights in the IR map you loose quality but gain time.
I prefer not to do it that way, but if your short on time it might have to do.
Best of luck :smile:
No but …
No but I can tell you that Katie Holmes is not in it :slight_smile:
Thanks for your help - I am sure it is going to be a hellish weekend we are presenting on Tuesday to the man himself so it is a big helping of stress all round.
Fun Times
Ahhhh ha.
Well its your mission to have thise finished by the weekend. And you have already accepted it :wink:
LOL
Good stuff mate.
