Strange behavior colored refraction
If I try to give a color to the glass material I get this result. If instead I assign a color to the fog, this is correct. I have Cinema 2025.2.1 Vray 7.10.00 OS Mac 14.7.1
Up to version 6 everything worked correctly​.
Luca
Hey @luca_bazzini , this has always been the same and has not changed since V-Ray 5. Have you by chance previously used a Standard (Cinema 4D) Material - the “Transparency” color from it is translated as a “Fog Color” in the V-Ray material?
Ah! ok! so it’s been a long time since I needed to create stained glass. The last time was with a version 3.
Thanks​
