Hi everyone, I posted something in the chaos Vantage forums about an interesting issue I discovered with reflection maps and live link and they told me to repost here as well:
Found a very odd bug with live link and corona: (see images)
Simple reflective material with a reflection glossiness map - works perfect, but as soon as I apply a diffuse it loses its reflection map
Diving a bit deeper into this: (and keeping exactly the same dirty/smudgy reflection glossiness map)
If I apply a corona colour with white (or something light) into the diffuse it overrides the reflection map entirely and gives a perfect smooth reflection!
If I apply a corona colour with black or something dark I get no reflection, (or half (semi reflective) if I were to apply grey).
I’m pretty sure if we also apply a light picture into the diffuse we will get some reflection where the light parts are.
Somehow the diffuse slot is hijacking the reflection?
This only happens when using live link, If I export to vantage from corona (without using live link) all reflections are correct. - - - -
See attached images, I did some tests.
These tests are using a fresh scene, which I tried after realising it was happening in other scenes
I’ve tried using corona phyiscal material - same issue
Tested on another machine and same thing happens
Im using corona 12 hotfix 1, MAX 2024 fully updated, Vantage (latest), Win 11
Thanks for any help, really excited to use live link as I love vantage, just confused why this is happening.
Heya, just flagging that this issue is still present.
I’m wondering if it has been forgotton? It’s a bit of a shame, because Vantage is genuinely amazing — the exported scenes work flawlessly, producing near like-for-like renders compared to Corona and Max, with reflections looking spot on.
However, in Live Link, reflections are still broken as per my original description, resulting in flat-looking materials which are nowhere near to Vantage’s true performance. If someone were to try out live link for the first time, it might give the wrong impression. Only want the best for you guys
I tried it again using corona 13 today and it’s still the same thing. In fact, I rendered out some specular passes this time and you can very clearly see that the diffuse is hijacking the reflection. The ‘exported scene’ is correct and identical to max and corona.
As Tom mentioned, diffuse + roughness should be working fine now, but there are some combinations which may not be working correctly yet (e.g. roughness + IOR or roughness + metalness). We are working on fixing this as well.
