i encountered some weird artifacts in my latest renderings (you have to zoom in the image to see it better).
this may look like a D.E. problem, but could’nt figure it out yet.
has someone had this problem before?
is there a solution? have already done a search on the forum.
i’m running Max9 (P.Booster) on XP64 and Vray 1.5RC3
it has nothing to do with DE so far, as the problem persists.
the irrmap is already quite high (-3,-1, HSPH60, IntSp. 20).
it’s the bump on the wall that causes those strange spots.
when i disable the bump, they’re gone.
how can i still have the bump on the wall without those annoying artifacts?
is there some workaround? have i to use a normal map instead of a bump-map?
thanks for further help.
here are two pics that show the problem i mean.
there is seriously some kind of bug with the bump, as when i remove it,
the problem’s gone. never had such weird results in prev. versions (1.47.03) and there isn’t any kind of modeling issue.
Hmm your LC info is missing, could you provide that as well.
Having not used DE much myself, you have set the radius to 20CM thats seem way to big to pick up any detail. I would suggest dropping it alot. Try 2-5cm see if that makes any difference.
I could also be releated to your LC.. but unlikely.
<edit> scrub that.. just read the info on it and it seems to be the opposite of my thinking.. heck try it anyway. lol
If you could try with DE off as well that would be great
See how in the bottom of the last larger image that you posted.. there is clear circles down there. That would be either the DE or LC I believe. *just a hunch*
Is this for an animation? if not switch DE and LC back to screen (for their scale). In LC untick the following to be safe, “store direct light” “adaptive tracing” and “use directions only”
Also your filter size needs to be lower. general rule of thumbs is keep it around 4x your your sample size.
okey, seems there are plenty of things i did not get yet.
these settings are for stills, so i’ll stick with screen mode.
i’ll report the results.
thank you again =)
the pic is still rendeirng, but i can confirm that it solved the problem so far(with DE on) =)
although there are some lightleaks now (depending from LC i suppose) that i have to fix.
what are reasonable LC sample sizes in screen mode for a resolution of 1754 i.e.?
i’ll show some results when all the troubles are gone.
well I think it’s DE, because you get more details in bumpmap compared to irrmap only. if the radius in DE is the distance of this “glow” around the objects, then my theory is true.
yes manuel, after some testing i think that too.
i should try QMC for primary bounces just to check if the bump
is equally over the most par of the walls.
