I was just wondering why I get “clusters” of samples on a smooth one color surface, why isn’t there an even distribution of samples. Is there some setting that is wrong or is this normal?
se pic. http://www.svenskdesignab.se/samples.jpg
i am not sure, but i ve retained the idea that calculating irmap and Lc localy would always be safe-proof.
but now that u are at it maybe u could run a quick test?
Also, you will get such “clumping” if your hemispheric subdivs are too low and your color threshold for the irradiance map is too low.
In that case, the samples will be noisy and with a lot of variation, and the irradiance map engine will think that there is a shadow there which needs to be sampled more.
A solution would be to either increase the color threshold, or to make the irradiance map samples less noisy (by increasing the hemispheric subdivs, or decreasing the DMC noise threshold, or both).
