Hi to all!
I am having a strange problem with DR which I’ve noticed 2 days ago at my home studio.
I have 2 PCs, my main is an AMD Ryzen 5950X while the secondary a 3950X.
I’ve installed the latest corona-9-3dsmax-daily-2022-06-09.exe on both machines.
So this is what is happening:
If I send the DR job via Backburner to the 3950X and I use my main PC 5950X as a server, while the DR process gives me no errors, I am noticing the following issues:
- Rays/s total is around 5.300.000 with both machines while the 3950X alone is around 3.500.000.
- Estimated time doesn’t change and remains at 6hrs approx.
- Remained timing for the image stays the same!!! Doesn’t matter if the 5950X contributes or not in the DR render process.
- Under Passes total I see the total number of calculated passes and in brackets () the DR server’s ones submitted normally.
- I get no errors to any place as DR seems to work normally but for me it doesn’t.
If now I do the opposite, I use the 5950X as the main PC and the 3950X as the server, the DR process behaves as it should:
- Rays/s total is now at 7.600.000 (before was 5.300.000)
- Estimated remaining time is 3hrs (before 6hrs).
- Under passes I see the same behaviour (the 3950X is a bit slower).
So basically, when the master is the 3950X the DR performance is almost ZERO even if the passes seem to be calculated correctly by the fastest machine which works as a server.
If the master machine is the 5950X, DR works perfectly by summing the results of both machines correctly.
I don’t know if the problem is clear to you and if I’ve described it correctly but I see a sort of degradation and it seems that something is blocking realistically the DR process if the master machine is one PC and not the other…
Last thing to mention, I work under Win 11 Insider Beta Release for both PCs.
Thanks in advance!
Dionysios -
