Strange Foam Behaviour… Version 3.05.00
What if you increase the falling speed of the foam, does that help?
Hello
Yep, i increased the falling speed and waiting the result..
Thanks!
Tried with falling speed bigger, smaller, it still hovers over the surface,no displacement, i am lowering the vertical offset of foam to compensate it..
Hmmm, how does it look in animation? Maybe there is a different problem that needs a different solution.
Cheers!
The foam always hovers above the liquid, I assumed it hovered 1 voxel above.. so higher res will get it closer. This is why I asked for the vertical offset a while ago which Svetlin put in ![]()
Ah yes, but it’s just half a voxel - this make me wonder if the offset in the shot is half a voxel though - then the scene has an extremely low resolution, or the camera is zoomed in quite a lot…
i guess it should be a matter of resolution, i have to go real high cause i am really close to the surface
thanks)
