Strange glass material
Hello guys, im facing problem where my glass starting to look grey when i enable global volunetric material no matters how much i put distance. The color is in the middle and and scattering also in the middle. Am i doing something wrong?
Best regards
Please attach screenshots of the settings, in as much detail as possible, and also the render, with and without global volume.
This will help giving you the correct advice.
I uploaded material, render and global volumetric
Also swimming pool strange pink color as you can see.
It is default water material from corona
This seems to be working as expected.
For the window glass - you are using a material with lowered absorption and a gray color. This makes windows darker. Perhaps a better choice would be using “Thin shell (no inside)” option at the top of the Physical Mtl’s settings. This removes refraction and any volumetric effects but you can still control how “dark” your glass should be.
For the pool water - do not use any scattering color (just set it to black). Use absorption color and distance only. Otherwise you are simulating tiny gray particles scattered in water. Absorption is set to blue so white light is filtered and becomes pink.
