I’m trying to use IES profiles for ETC Source 4 stage lights. When I render out a spot, it also comes with a a dim square around the spot on the floor (see attached file). Is it possible to get rid of the square?
Also, how do I attach an image to the light source so I can project it?
Are you using the IES files which are bundled with Corona? Can you share this scene with us (with assets included)? Chaos
I don’t think this is expected…
It’s not happening for me with the IES profiles provided with Corona (and using a CoronaLight, haven’t tested other light types) - I am getting the expected results.
On the second question, simply drop a CoronaBitmap into the Texmap slot in the Color options for the CoronaLight (and check the button next to Texmap). Depending on how sharp you want the projection to be, you may need to increase Directionality (but be aware that higher Directionality means more noise, so longer render times) - in the example below, so that the pattern was visible I raised Directionality to 0.9, which is very high
Slightly OT, but is directionality embedded into or taken into account when using HDRI’s as environment lights? If not, would having directionality controls make any sort of real world render mood difference (either for HDRI’s or Corona sun/sky as main light sources?)
