Hi , weird result with opacity and leaves and shadows issues.
Maya 2022, Vray 6.2, Windows.
Scene sended. DB9Y-N72W
Whatever it is, it seems to be fixed in the latest V-Ray 6 stable build. Try it out.
Thank you, it seems to be something with shadows. If you delete the trees that are given this soft shadows this weird effect disappears.
I will give it a try.
Hi, it seems to be corrected on V-ray 6 Stable, but not in V-Ray Standalone 6. Is it posible to get that fixed and get V-Ray Standalone?
There is an analogous build for Standalone, too (here). It seems to be the same version number (33437). Is this the one your tried with?
Yes, please give it a try too if you want. Seems to be really strange that it is fixed on the Maya version but not on the standalone
Okay. I reproduced it. Will investigate and write back.
Well, it seems to be fixed in V-Ray 7 Standalone. I debugged it, and it seems to be caused by the “Conserve memory” option (Render Setup > Settings > System > Conserve memory). As a workaround for STD, you can disable it.
Ok, thank you
