Strange problem: It doesnt render objects and lights
Hi.
This is a repeating problem i’ve been having since 1.5 all the way to 1.6 DB
I’ve been having strange problems with rendering. In the 1.6 DB materials with refractions render wrong, like in attachtment 2. They suppose to look like attachtment 1, just some plasticky tubes. After this if I activate IR or make a render…well, nothing renders (attachtment 3)..camera is working and all you can see in the image is background color or enviroment image. Everything gets back to normal after restarting 3dsmax. Wich is really problematic now because we need to render an animation… It happens with backburner too. It renders fine for 8 to 10 frames, then..all renders without objects..
I’ve tested with max 2014 too and we are having the same problem.
Max 2017 is with SP3
Win 10 x64 ..
I just cannot think of any solution. The only thing I’ve notice is first the problem with refractions and after that just nothing renders…
I’m doing some material testing for some styleframes for the animation, so the screenshots reveal several materials, and just the ones with refractions are having the problem…
Corona after clean Install …latest DB
Moved all assets to a Local Drive.
Strange behavior …Renders are different each time and last one, all objects are “gone”
Should I upload this to Mantis??
Moving to bug reporting boaed.
Please contact us about this via support@corona-rendere.com and send us the scene if possible.
You can also try these solutions:
https://coronarenderer.freshdesk.com/support/solutions/articles/12000019571
https://coronarenderer.freshdesk.com/support/solutions/articles/12000015667
Old, probably resolved.
