Strange Raw light
I can’t understand why saving separate channels of my scene what I get from the ‘raw-light’ channel is this
while the final picture (not composited) is this one
thank-you
its a known issue that if you try to render multiple lights into raw light it wont work, this is fixed in newer builds.
Thank-you
We are on version 1.47.03 and we are having the same problem only it took us a whole day of trouble shotting to figure out that was the problem, what is the version that is works in? or does anyone know a work around to build a normal diffuse (like scanline or mental ray) We are not using GI on our project, and if we cannot find a solution we will have to switch render engines for this project, and I love vray :frowning: i can post samples if it would help. Our final deliverable for our project is to hand off plates for another company to comp.
you can eather write to chaos to request a new vray build, which most likely they will give you as it affects your project completion. Or manually create each light as a separete pass.
thanks we will try the first solution, and hope for the best, thanks again…
well while we are waiting to hear back from them we tried your other suggestion, tons and tons of footage but it does work, thanks
