I get this strange dark reflection on the table. It does the same on the chair and whatever material i use. It does the same on a new cylinder created with Max. Can you help ?
Corona 8
Max 2018
It is the “black highlights” issue listed here: https://support.chaos.com/hc/en-us/articles/4528311915025-Known-bugs-and-limitations
It is usually caused by:
The safest solution is to restrain from using unphysical effects like the above.
Thanks, found it!
I had an object with > object properties > visibility > 0.5
