Hi, I get strange reflection spots with carpaint2.
In my example I am using Vray sun+sky with default settings, carpaint2 with default settings and a cam with 100 / 16 / 100
Vray CPU only / Windows / S24 / one of the latest vray night builds
I don’t get rid of the strange white spots. Only if I am lowering the coat amount. But then the material gets less realistic.
I claim this shouldn’t be, or? Any help much appreciated. Thanks.
Hi, they looks like the sun disk reflection on the coat layer, try to disable the sun visibility in reflection to be sure. If that’s the sun then you can play with lens effects to get a more realistic result, in real life bright spots should produce bloom/glare. If you can share the scene I can check;)
Hi Sirio,
yes, thanks, when I switch the sun to invisible, the spots are gone. This could be a workaround, but this shouldn’t happen, or not?
I’ve played around, it is not happening with carpaint only. Same with a standard Vray material..
Regarding lens effects. I sometimes prefer it in post, as sometimes clients don’t like it, so no need to render it again..
