If that’s very low poly mesh, then this result is probably expected. I don’t have C4D, if you’d export those meshes to OBJ format, i could chech how it renders in 3ds Max.
N-side spline, R: 200cm sides : 200
duplicate it, Change the R for the thickness u want, if u want 1 cm R: 199 , 2cm R:198 etc
Edit splines, delete the part u want (see attachement 1), connect and delete the splines. Close the spline (join points)
Add a revolution with high subdivision for ur spline.
