Hey y’all,
I’m trying to do my first render with Vray for Sketchup, and I’m running into a problem that I can’t find addressed on this board. My image is washed out, but it also has strange white dots. Has anyone else run across this problem, or know how to fix it?
Re: strange render appearance: white dots and washed-out colors
Just disable show samples under IR settings and those spots will be gone.
Didn’t work :-[
But this is helping to narrow down the problem: the blue panels are being rendered as default (all of the other colors are correct, and the background is blue), and i can’t get rid of the white dots.
Those dots represent the IR samples being taking. ??? It’s weird that un-checking the show samples didn’t solve it. What I would do is restore/load the default settings and twitch them from there.
and you also should probably up the IR map subdivsions and samples, my rule of thumb is always do the samples 1/2 of the subdivisions, so like 80/40 would be a good setting.
