Strange result when including/excluding objects from light, help.
I am getting confused when I am trying to use the include/exclude parameters for lights in vray. I have done three images that illustrates the problem
LightOff.jpg, the light that uses the inlude/exclude parameter is turned off.
LongCylinderNotIncluded.jpg, the light is turnded on but the long clyinder is not included for the light. Here I would expect that the four blue cylinders would be effected by the light but the long cylinder would not be affected at all. The problem is that it gets effected by the light, anybody knows why?
LongCylinderIncluded.jpg, the long cylinder is also included in the light. A small difference on the long cylinder compared to the LongCylinderNotIncluded.jpg image.
The light has the invisible parameter checked.
Thanks for any input.
Roger,
