Hello, good people of Coronia!
I need your help once more and hopefully someone can help me crack this…
I’m doing an interior render for a client and I ran into a problem with weird specular reflections coming out of seemingly nowhere.
The problem is as follows:
First, the reflections make no sense whatsoever - they appear in the shadow areas where the angle of view would probably reflect the dark wall anyway…
AND
Weirdly enough, it happens on the side closer to the camera. The floor looks fine further away:
Now onto the details:
I’m using my usual setup for parquet - a texture set bought from turbosquid (includes diffuse/ref/bump maps), somewhat reflective, half-way glossy…nothing special. I’ve double-checked that my texture maps are at blur value of 1 (default) and are not sharpened or overdone. Bump is at 0.3, the bump map itself is between values of 20% grey (tiles) to black (crevices), so nothing extreme either. Here’s the shader itself (note that it renders fine in the preview):
I’m using Corona Sun&Sky to light the scene, default settings, nothing special once more:
This is the same scene that I was having trouble with black highlights on the sofas. The workaround was to render with no glass refractions for the skylight (roof) and render the frosted glass as a separate pass to comp in later. I can live with that. But the hite specs appear regardless of whether I use the frosted glass or nothing at all, prompting me to thing it has something to do with the engine itself or the way shader/light are set up?
Here’s the overall view:
Dropping the obvious out of the way:
- I’ve tried rendering with both frosted glass, no refraction and even no glass at all. Same results.
- I am not willing to render without the bump map as it gives the flooring realistic look when looking at it against light.
- The lighting has been approved by the client/director - I can’t go to an HDRI easily now.
I hope someone can help with this issue as it’s quite obviously destroying the picture. Please don’t tell me this is an engine bug just like those black highlights (https://forum.corona-renderer.com/index.php/topic,6883.msg53754.html#msg53754) ![]()
Thanks!
