Strange ..
Looks like some standard splotches - the scene is hard to render with small openings, as demonstrated by high level of noise in PT+PT image. Try increasing “PT samples” in HD cache rollout (2 to 10 times more)
with PT samples = 1125
Shouldn’t precomp step be set to 1?
As maru said precomp should be 1
ok, i did with precomp=1
can you post the scene without the statue so I can give it a try ?
yes, np, max 2012
LI.rar (19.4 KB)
try increasing position sensitivity of HDcache
you’re right, thx
Are you sure it’s fixed ? Not for me
Keymaster, the green spots in HDcache pre computing are primary bounces ?
indeed much better lol
Keymaster, even with position at 100 there still is a problem compared to PT
That brighter region corresponds to the green spots of HDcache, for some reason it doesn’t blend well.
green spots are where HD cache was not used at all
pos = 70
i think good.
because your render is too dark, try with exposure compensation at 1 and highlight burn at 1.4
possible, but even right now is better, the rest of the details. Now I’m interested glass in corona
Does changing values in Postprocessing tab affect stuff like antialiasing, sampling? If yes, then what happens when I change these values DURING rendering?
the core always uses the values from beginning of the render. But it is used only to correct max sample intensity.
