Greetings,
Have some issues for your consideration.
Using V-Ray 3.60.04 nightly 28450 and Phoenix 3.11.03 nightly 2018082528462.
Grid is 72 million, SPF 4, everything 1:1 scale, ship movement 25 knots.
Examples attached show frame 150 and 200. Yes I have the ocean level a bit high on 150, but it is settling out later. The shot is 3500 frames.
Significant streaks in the water surface show up through the displacement. Are some water particles stuck to the leading edge of the container?
Also the horizon is flat when the physical camera motion blur is turned on, less so (but still unusual flat) when mo-blur is off.
Turning off motion blur introduces dark artifacts on the wavelets. Turning on blur smooths out the dark artifacts, but the horizon really flattens out.
Smoothing increase from 1 to 2 has no notable effect on the streaks, Ocean subdivs 2.0. Horizon roughness 1.0.
Lighting is bright hdri with vray sun, and global illumination OFF, so render time is under 4 minutes on my small farm.
Any suggestions for improvement?
Thanks again,
Ron Porter
Mustang, Oklahoma
