I am using an ordinary direct light to shine through a fixed window with 9 panes of glass and I wish to use a volume light effect to make it look like streams of light are pouring through. I also have a sky background and when the density of the volume light as applied to the direct one is 0.8, then the sky background cannot be seen, but nonetheless I cannot create the effect of streaming sunlight,
I am using the standard volume light effect, but hve had some succes by using the shadow map, on the direct light however I have tried to find the VRayEnvironmentFog but without success where do I go to get this? as I will give it a good go when I do
