stripe with distributed rendering
I use the distribution from out of the alpha 6 (and it’s great!) But on this scene, it produces a bug: a stripe appears and moves vertically as the report retrieves data slave.
I thought about a problem with Gamma but my two PCs have the same setting ..
Any idea ?..
(sorry for my English^^)
Ok, I think I found where the problem was: I used MultiTexture from CGsource to the floor, which should generate an aberation in gamma between PCs. I replaced by a Multi Materials / Material by element and the stripe disappeared ^ ^
For cons, the control is not the same, it’s a little shame …
ok, multitexture problems with DR are known and discussed in other thread
