I usually use multiple window lights and not one large light. Not sure if it still holds true but in the past using one large plane made the rendering much slower than several small planes. My guess it has something to do with samples needed to deal with the extremely large surface area of the Vray plane light.
Is there an actual vray reset button (so I unscrew all those settings
I guess changing renderer would reset it.
Turn off probabilistic lights.
Change lots of lights on the sides to one big light. Dont make portals. If you use hdri and all vray lights are portals, dont use them at all.
Maybe there are more fix should be done, but without scene hard to tell.
Now I see some picture of your settings - its little bit odd. Use automatic subdivs or make brute force subdivs higher. Or use Irradiance map with some high settings.
Yes, please send the scene to support@chaosgroup.com (request access to our FTP if needed), and don’t forget to include a link to this thread in order to find easily where it came from.
There seems to be an issue with the Multiple Importance Sampling in this particular case. I’ve forward the scene to the developers for investigation.
For now you can either disable VRayDomeLight “Use MIS” option or you can revert to the old sampling method:
renderers.current.twoLevel_adaptiveMethod=0
Hm really! I was certain I screwed up some threshold with Solid Rocks or vray quick settings.
Thanks but what do you mean to use MIS and disable vraydomelight?
There is a MIS option in the Light Options:
Disabling that option for the DomeLight in the scene will resolve the artifacts.
Hey guys,
has the
changed with the new vray 3.50.04? Now I have s scene where this does not fix the weird noise. When I disable “use MIS” I get different noise.
