We have just had a new machine built, spec’d by Workstation Specialists, but as per the title I’m struggling to use VrayRT with it. I’m new to RT by the way, though I have been using max/vray for years - I’m also no I.T. guru! (it does seem like you have to be an IT guru to be a visualiser doesnt it)
Installed is a:
AMD FirePro W9100 - 16GB GDDR5 Workstation Graphics Card, and a
AMD FirePro W5100 - 4GB GDDR5 Workstation Graphics Card
Vray 2.50.01 - Max 2015 - Win7
If run a small test scene with RT it seems ok. But textures are not being rendered. Switch to Production render and textures render fine. Same occurs with Proxy’s..
So is there some magic button tucked away somewhere to ‘enable epic GPU rendering’?
‘I.T’ at work dont know what to do. Workstation Specialits don’t know.. so I look to the all knowing Vray forum for help
Here’s some images to explain - we all like images don’t we
Try absolute file naming? Are your files on the network? Some functions require the pathing to be by machine, so instead of H:/Projects/etc. you’ll need //Bubo-Archimedes/Projects/etc. (Using example computer name of Bubo-Archimedes) (Not a Vray thing per se, but a max thing in some cases.)
Did windows throw up a firewall warning the first time you started RT? Maybe the firewall is blocking your ability to get files over the network.
