I am currently working on a scene using 3DS MAX design 2010, the latest V-Ray, and DR. It seems the render is stuck with 2 buckets left. The estimated render time is 2:39 minutes, but it has been there for 4 hrs. Max hasn’t stopped responding, but it seems v-ray has. This has happened before on different scenes. Lucky I am not under a deadline so I am going to kill it, but does anybody know what would cause this?
I know about the issue as it has happened before; I haven’t been able to reproduce this here successfully though. If I manage to reproduce it, I’ll fix it.
I have recently created a scene which has this problem. All 8 of my buckets get stuck on the same place everytime. The area is looking through glass at vray proxied onyx trees which are placed on top of vray displacement grass with a simple plane behind for mapped textured trees. Now, if I region render this area there is no problem, if I render full at 3000px all buckets get stuck…forever. This doesnt hapen from other camera angles on the project. I have tried moving stuff around, changing material settings, the only way I can get it to work at full size is to remove the backround plane.
I had exactly the same problem with a large render I did recently. There were 3 buckets that didnt render…i ended up cancelling the render and cloning them in photoshop..luckily it was just a grass area, but any detailed areas I couldnt do this !
I was just preparing it to send you and decided to hit render one more time after installing SP4 from SP3a. I dont know why, but installing SP4 seems to have stopped the problem. Buckets are not sticking. Do you still want me to send you the scene Vlado?
I think I had the same issue yesterday - buckets would randomly stick forever, cancelling the renders results in crashing max completely. As with Dan’s experience, it seems to happen mostly on areas looking through glass, in my case its happening just on a bit of plasterboard.
(I’m using SP4)
To get it to render I decided to try rendering in strips via BB, then I noticed that my slave wouldnt start as it had vrayRT (SP1) installed as a slave only and not as a main workstation. I reinstalled vrayRT and BB worked fine. Note that its buckets on my workstation that stick when I render with DR, not the slave.
I’ll try another DR render today and let you know how it goes, plus will try and get you a copy of the scene to test if you still want one.
I have stripped the scene down and removed the HDR and it still hangs on certain buckets. Vlado, do you want me to send it to vlado@chaosgroup.com (its approx 9mb zipped)
You have environment fog in this scene with a mesh gizmo, which is the reason for the stuck buckets in your case. I’ve already corrected this for the next update (of course, in SP2 there wasn’t environment fog).
i have 4 machines over here rendering a image with DR actived. One of them usualy freeze one last bucket without reazon. Vray sp4 and max 2009.
any tip to solve the problem?
when i am waiting and look at the problem i jut cut the vrayspawner from the especific machine and then another one assumes it and finish the calcule pass but with i send a night render, it can take forever and cant finish the prepass render to start the final render.
thanks in advance for any help.
ok, we are running into this issue. Frame before and after (all look similar) take 20 min to render but this one frame is stuck with 2 buckets in one place and is taking 8 hours with no end in sight. It happens on the random too, some frames render then they wont.
no displacement in the scene. Here is what I have found. The vray messages prints material overbright warning. The material is a multilayered vray blend with additive mode. The lighting is simple area lights + dome light with brute force.
I have reduced the buckets to be 15 pixels and i can see the certain area where few pixels it cannot resolve.
