otuama
1
Hi all,
All of a sudden 2 systems in the office (including mine) are getting stuck on rendering over the network.
maxcmd.exe loads but it’ll permanently hang on Transforming Vertices.
I noticed it with a job a couple of weeks ago but took it for just one of those things.
I’ve tried turning off Windows Defender/Firewall & Malwarebytes but it hasn’t fixed anything?
All systems are using the same version of Max & Plugins
Any help would be great,
@Otuama I’ve started a support ticket on your behalf: #303177
Can you try the following solution, maybe it helps.
[https://forum.corona-renderer.com/ [solved] Transforming Vertices - rendering stucks ](https://forum.corona-renderer.com/ [solved] Transforming Vertices - rendering stucks )
otuama
4
Thanks both,
After a while of testing I found the cause - Anima
We have 2 licenses but it seems to be hit and miss whether they work.
I eventually got the licenses working on the 2 systems and they started rendering.
Nazar, thanks… The support link you sent seems to be broken - getting an Oops page but the solution seems to have been found anyway
Thanks again
