SU Chain link material doesn't render properly
I have followed the instructions on V-Ray4SU Manual and I didn’t get the shadows for it.
By the way, I disabled the ‘invert’ - what is said to be enabled in the manual. Did I do the alpha inverted? Black in Ps is full transparecy, eh? If I enable ‘invert’ I get no transparency.
However I’m happy I got transparency. :slight_smile: (but what about the shadows? Is it possible?)
Re: SU Chain link material doesn’t render properly
VfSU treats white as transparent.
Consider the colour values: 0,0,0 = 0% transparency - 255,255,255 = 100% transparency.
Well, problem solved. Thanks Thom.
In fact, you must put a good config for the shadows to appear, since the chain link represents little of the face. It worked with ‘invert’ disabled…
Gustavo
