SU Enscape materials: Inverted bump-maps make texture black
Occasionally I use brick textures with a light morter joint that I want recessed. There is the option in the Bump tab to invert the image used - when I tic this I get a black texture.
{Note: Simple solution is to set the bump amount as a negative value rather than positive on the general tab.}
I was having the same problem with Revit, and unchecked invert and got things to look correctly again. Thanks for the tip.
Fixed in 2.3.2.1147-g524138a preview
